candyman214
#1 Posted : Thursday, February 12, 2009 6:13:45 PM(UTC)
candyman214
Hi, my washing machine is having a problem. It is not stopping at any point but going all the around through all cycles, it occassionally cuts off(generally it has water in it when it does this) and then we have to turn the knob around and keep pulling it out until it comes back on.
I think it's a bad timer (please verify this if you can) but this brings up another interesting question to mind. Are timers interchangeable or are they specific to that model only? I ask because its a 115V/60HZ 3 cycle timer and I'm wondering if any washing machine timer that fits that description will work because they vary widely in price?
Any help would be greatly appreciated.
Thanks,
Candy
#2 Posted : Friday, February 13, 2009 5:12:22 AM(UTC)
Model LWA30AW
Here is a service manual which may help you confirm a timer problem
http://www.servicematters.com/m...ary/docs/RS3100005R3.pdf
It does sound like a timer problem!!!
Timers are not universal (timing cams and contacts differ from machine to machine), so you must get the correct replacement for your unit.
candyman214
#3 Posted : Friday, February 13, 2009 11:01:54 PM(UTC)
candyman214
Thanks so much for all your help.
One last question. I'm kinda confused, the diagram shows a timer as being part number 7 but then two parts are listed for part number 7. The first one is Part Number: AP4047042 made by WHIRLPOOL and the other is Part Number: AP3757325 made by SPEEDQUEEN. Does this mean I can use either one? Please tell me it doesn't mean I need both.
Admin / APP Team
#4 Posted : Saturday, February 14, 2009 12:44:54 AM(UTC)
Admin / APP Team
Rank: Administration
Groups:
Yes, you can use either one (I'd pick the cheaper one). Here is why: a while ago Amana bought Speed Queen (this is a speed queen washer under Amana brand), then Maytag bought Amana. Then right before Whirlpool took over Maytag, Speed Queen decided to go its separate way. So now you have two pretty much identical timers - one made by Whirlpool and one by Speed Queen.
Guest
#5 Posted : Sunday, January 7, 2024 6:36:26 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Are there any timers that are compatible with the 10536 like 10535
