bubbles76
#1 Posted : 16 years ago
bubbles76
I have had no problems with this washing machine up until two weeks ago when it just started leaking.
Leak comes from below the washer in the middle, filter doesn't say it is blocked no fault codes come on.
I have checked all connection pipes and there is no water to be found.
It is alot of water that pools underneath.:eek:
madden611
#2 Posted : 16 years ago
madden611
I have a whirlpool washer that is about 15 years old, and has worked perfectly until the past month or so . . . every wash produces a fair amount of water beneath the machine. I am in the process of remodeling the room and am going to attempt to fix the problem before I put the dry wall on the wall next to the washer.
What was the remedy to your problem?
Whirpool leaking water around pump (Dishwasher Repair)
by gitrman60 13 years ago
