LuvBJones
#1 Posted : Monday, December 12, 2011 10:37:15 AM(UTC)
LuvBJones
This dishwasher was working fine when we moved into this house about a year ago. Now having trouble draining. Old owner's manual suggests clearing the drain air gap, but there isn't one on the sink. It looks like there is only a drain line to the disposal unit. Previous owners had done extensive remodeling in the kitchen. Is it possible for this unit to run properly without a drain air gap? I'm about to pull the drain line out for inspection and cleaning, but I'm baffled by the missing gap.
ApplianceJunk
#2 Posted : Monday, December 12, 2011 10:47:27 AM(UTC)
ApplianceJunk
The disposal unit will act as the air gap if the disposal is open on top.
LuvBJones
#3 Posted : Monday, December 12, 2011 10:49:06 AM(UTC)
LuvBJones
Thanks! I'm checking the drain lines now.
#4 Posted : Monday, December 12, 2011 1:44:10 PM(UTC)
Here is a pretty good install sheet that applies to most units.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=31-30515.pdf
If the unit is not draining at all make sure the disposal plug is knocked up.
If draining but leaving water in the tub make sure that the drain hose is looped higher than the disposal dishwasher inlet.
Guest (4)
