Looking for info on testing timers....
TIA
These totally enclosed plastic timers are pretty reliable. If you suspect it is bad, you can try spraying a non-residue cleaning spray into the opening by the connector while turning the timer knob. This spray is available at Lowes.
Here are your parts Model DU915PWKT0Here is a tech sheet with wiring and timing chart https://www.servicematters.com/d...0Sheet%20-%208275137.pdfYou did not say what/why, you want to check!!! If the motor has 120 volts across it and does not advance the timer is shot. If it is contacts you want to check you have to disconnect the timer, manually rotate it then use the timing chart and a meter to check if the correct contacts are closed. |
THIS FORUM IS DEAD!!!!!!! |
Thanks Guys.......
Supposedly the timer will stop and not advance in different places from time to time.
So, not relying on someone else’s input I begin to check operation. I ended up testing everything and all checked OK to the best of my knowledge.
The timer is the one part I wasn't sure about testing properly. It seems to turn a little stiff, but runs through full cycle with no problems.
Any Ideas.....on Intermittent operation. (Unfortunately no one can tell me which part of the cycle it tends to stop)
"RICHAPPY" are you referring to QD contact cleaner.........
Thanks again guys.....
Any NON-RESIDUE contact cleaner made to electronic/electrical cleaning will do. Sometimes low current contacts will get dirt on them. A combo of spray and turning the timer knob will clear them.
