i have replaced control board -rinse light wont clear -washer will not run - what do you suggest ? thks hal
Could be a stuck button on the control panel. I researched your model number and could not locate a tech sheet.
Try removing the access panel at the bottom of the dishwasher to see if you can locate the tech sheet. The tech sheet should include a troubleshooting guide and information on how to run diagnostics.
I followed your suggestion and pulled panel on bottom and there was no tech sheet there. :mad: Do you know anything else to try? I will go to appliance parts store tomorrow and try do see if I can get a trouble shooting guide or manybe you can tell me how to obtain one. tHANKS hALS bELLS
