wxdude3
#1 Posted : Sunday, December 11, 2011 12:03:21 PM(UTC)
wxdude3
I have a WhirlPool dishwasher. I recently replaced the thermal fuse. I did not replace the harness (wires) After three loads the fuse has blown again. Question: Is it necessary to replace the harness? If the fuse continues to blow...What are the next steps? I have checked power suplly, switch etc...all seem ok
G
ApplianceJunk
#2 Posted : Sunday, December 11, 2011 12:11:04 PM(UTC)
ApplianceJunk
Yes it is necessary. The reason being is that the old wire harness can have bad connection and bad connection can create heat. To much heat is what opens the thermal fuse.
