tripperMM
#1 Posted : Monday, February 9, 2009 8:25:34 AM(UTC)
tripperMM
in 07/07 we bought this from sears. glass top range. electric oven. saturday eve, we cooked a pork loin, no problem. done in specified cooking time and everything.
sun morning we went to use the oven and there is no heat on either element inside. nada. the stove part still works fine, tho. the oven clicks like it's trying to get started. is there a fuse to replace (hopefully) or something "easy" to fix? or something that is a recall item that they'll replace? i really can't aford 75 bucks for someone to replace something so trivial. :(
thanks,
tripper
#2 Posted : Tuesday, February 10, 2009 4:19:10 PM(UTC)
Most likely the problem is a bad control board (aka a clock). It has to be replaced together with the overlay because it's glued to the clock.
- The part number for the clock is AP3960228
- The part number for the overlay is AP3760273
tripperMM
#3 Posted : Wednesday, February 11, 2009 4:04:19 AM(UTC)
tripperMM
thanks for the info!
#4 Posted : Wednesday, February 11, 2009 3:04:31 PM(UTC)
