Lovsexy4
#1 Posted : Monday, February 9, 2009 8:25:30 AM(UTC)
Lovsexy4
Hello,
I need to install a motor/pulley, Blower wheel and plastic housing cover for a kenmore laundry center dryer. Is this an easy install I could do myself or should I call in a service tech. I already have the parts, and was quoted around $250.00 for labor by a service tech. Trying to save money.
Thanks,
Joe
#2 Posted : Tuesday, February 10, 2009 2:17:34 PM(UTC)
Joe,
The model number you posted is incomplete. Verify and repost it.
Lovsexy4
#3 Posted : Wednesday, February 11, 2009 4:03:00 AM(UTC)
Lovsexy4
Model # is 417.993751-00 27' Laundry center.
#4 Posted : Wednesday, February 11, 2009 3:03:51 PM(UTC)
You have to remove the access panel (under the dryer), the front panel with the door and the drum in order to replace the motor. The difficulty of this job depends on the place where is the unit located because of needed access from the top, sides and possible, the back of the dryer.
Kenmore Laundry Center Dryer repair (Dryer Repair)
by Lovsexy4 2/11/2009 4:31:42 AM(UTC)
