Washer is not spinnig but is draining water. What could be the cause of this?
Originally Posted by: Gene  There is no led lights on the motor??
Originally Posted by: Al17  There is no led lights on the motor?? No led flashed on motor tested Fuse in harness. Fuse no good bypassed fuse washer working ok. replacing Fuse asap. thanks for the help..
You are welcome. You have to replace it with OEM part only. No any after market. - The fuse link (2 pack) Part number: AP4390012
Gene,
You seem to know your stuff.....I posted a similar question under user rogramjett yesteday. Need help!
GE Front Load
I am having the same trouble with GE washer WHDSR209G2WW It won't spin... And I can't locate a green light anywhere on the motor.. I was told perhaps the motor was bad... Now I am wondering if it could be this fuse... But I can't see the fuse in the harness... Does my model have one? I'm sure not wanting to get a new washer if I can help it... And yet if the motor is bad I don't want to pay a repairman to tell me that and the repairs will be more than I paid for the washer almost 6 years ago.... Thanks for your help...
