sduck
#1 Posted : Tuesday, December 6, 2011 12:36:52 PM(UTC)
sduck
My Bosch shx46a05uc /14 is making a loud noise coming from the lower left corner of the machine. I thought it was the pump so I replaced it. No luck. The noise seems to be coming from the Water Inlet Valve. The machine works but it is just making a terribly loud noise that started this past week. Any ideas?
Stephen
sduck
#2 Posted : Tuesday, December 6, 2011 4:03:48 PM(UTC)
sduck
Update. The DW was finished and the noise kept going. I turned off the breaker to the DW and the noise kept going. It was not till I shut the water off to the DW did the noise finally stop.
sduck
#3 Posted : Wednesday, December 7, 2011 8:43:16 AM(UTC)
sduck
Thank you MrMark52!!! There was a small piece of rubber that had stuck in the water inlet valve. I disconnected it, blew it out (a small piece of rubber shot out) and now there is no longer a noise. Again, thank you so much.
