#1 Posted : Sunday, February 8, 2009 1:19:07 PM(UTC)
Ok I've read most of the posts on this site but I'm actually trying to see if
there is anyway that i can get a description a better break down on how to approach the no heat to my gas dryer situation. the ignitor glows for about ten seconds but the flame doesn't come on at all i replaced the coils and still no luck thermostats are good sensor is good though i havent checked the thermo-fuse i tried to look for it in the parts section a but run to a dead end, do they even make a thermo-fuse for this dryer or are they just on some dryers. And if so where would the thermo-fuse be located, along with the heating element. My last question is if the gas valve is gone how would i check that and whats its function
#2 Posted : Sunday, February 8, 2009 2:38:37 PM(UTC)
Usually check the igniter current with an amprobe, rather rare a valve goes bad. Igniter current must be greater than 3 amp for the square ones.
#3 Posted : Monday, February 9, 2009 11:16:58 AM(UTC)
I have a multimeter is that fine and can check it with that, thats orginally how i checked the ignitor at first. also would you be able to tell me where the thermo-fuse is at on this model does it even have one and if not should i check the heating element.
#4 Posted : Tuesday, February 10, 2009 12:32:12 AM(UTC)
Check the flame sensor near the igniter, must be initially shorted.
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
LG gas dryer no heat (Dryer Repair)
by Guest 8/15/2021 10:28:45 AM(UTC)
by tombeird 11/8/2017 2:32:42 PM(UTC)
Whirlpool gas dryer no heat (Dryer Repair)
by alabamainnevada@yahoo.com 6/23/2015 5:54:15 PM(UTC)
Gas Dryer NO HEAT/FLAME and possible bad timer? (Dryer Repair)
by noles9399 2/26/2015 10:12:14 PM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
Hotpoint gas dryer no heat (Dryer Repair)
by Erich4130 8/28/2013 3:45:28 PM(UTC)
by huggard42 5/30/2013 4:34:58 PM(UTC)
Gas Dryer No Heat (Dryer Repair)
by AkZipper 11/29/2012 4:14:41 AM(UTC)
ge gas dryer no heat (Dryer Repair)
by mdelgiu1 11/7/2012 1:23:14 AM(UTC)
Ge gas dryer no heat (Dryer Repair)
by moby2000 10/25/2012 9:04:28 AM(UTC)
Kenmore Gas Dryer No heat (Dryer Repair)
by Resultsnow 9/8/2012 11:14:56 AM(UTC)
Gas dryer no heat (Dryer Repair)
by Brent gordon 7/31/2012 1:36:06 PM(UTC)
by petec357 6/21/2012 3:05:37 AM(UTC)
Frigidaire gas dryer no heat (Dryer Repair)
by mbarone 3/18/2012 4:25:38 PM(UTC)
