The dishwasher is not drying the dishes. According to the repairman this model does not come with a heated drying cycle, only an energy saving dry cycle. He said that he could install a heat dry unit along with a control panel that would provide that option for around $500.
After speaking with a tech at AppliancePartsPro, I don't think he was giving us the correct info.
What do I need in order to have a heat dry cycle that would dry the dishes?
Thank you
Wayne
Did it use to dry the dishes?
If (and it's a big if) what the technicians said was correct I would think that the control board and control panel would need to be replace from a model that had the dry cycle.
What option do your buttons give you on the front of your dishwasher now?
The control panel read:
Baked on cookware Normal Light/china Quick clean up rinse only high temp scrub sani rinse energy save dry 4 hour delay
hope this helps
Wayne
I would think with 'energy save dry' selected the dishes would drip dry and without it selected it would use the heater to dry them.
For the fun of you you should ask the technician that looked at it and see what he says about the 'energy save dry' option. :)
I did ask the tech about the Energy Saving Dry and he replied basically the same as you did, ie; drip dry.
Do you think I need to replace the heating element and add a board with that option?
Thank you,
Wayne
Quote:I did ask the tech about the Energy Saving Dry and he replied basically the same as you did, ie; drip dry. Yes, drip dry if it's selected and if it's not selected it should use the heater to dry them. Quote:Do you think I need to replace the heating element and add a board with that option? Your heating element could be bad, but from my experience I doubt it. To check the heating element I would simple disconnect the power to the dishwasher, remove the wires from the heating element and check it with my ohm meter. I believe the control board that is in your dishwasher now already has the option you are looking for, it's just not working.
Here is a copy of the tech sheet for your model dishwasher. It includes a troubleshooting guide that may help you better diagnose the problem.
My main question is: Does this model Kitchenaid come with a dry cycle in it's normal operation? Thank you for your assistance.
