i have a refrigerator that is to cold in fresh food side and has frost in the freezer side g e gsl25jta-bs
I would remove the back freezer panel and check for frost. If entirely frozen ove, defrost the coilswith hair dryer and re- check temperatures, then post results.
Originally Posted by: richappy I would remove the back freezer panel and check for frost. If entirely frozen ove, defrost the coilswith hair dryer and re- check temperatures, then post results. i will check that thanks
