ibdavid
#1 Posted : Saturday, February 7, 2009 4:53:03 AM(UTC)
ibdavid
My asko 3122 seems to be "stuck" at drain cycle as far as i can tell. The normal load indicator light is flashing at it is making a sucking noise as if in drain cycle. Also it is not repsonsive to the on/off button start/stop or any other front panel button. I have to kill power to the outlet or unplug to make it stop. Any ideas? Is there a key panel press method to reset the unit?
#2 Posted : Saturday, February 7, 2009 5:46:21 PM(UTC)
Most likely there is water in the dishwasher base sensed by the control. Remove the toe panel and check for a water.
