Dishwasher was working fine now it won't run a cycle. I've reset it before and it runs fine. This time when I reset it the "normal" wash light comes on and it runs for a few minutes then switches to "rinse only" and runs for a few minutes then stops. I can get eh normal cycle to light up but not the heavy cycle. When I press start nothing happens. Any clue as to what I can do without paying a repairman an arm and a leg?
Sounds like a problem with the control board. I would remove the toe plate at the bottom of the washer and look for the tech sheet. It should tell you how to run the diagnostic test to check it out.
