My wall oven was giving me an Error code of F3 after heating up for 5 to 10 minutes. I reviewed other post and found it should have been a bad probe. I ordered the probe from you, installed it and now I am getting an F1 or F3 code when heating up the oven. What would be causing this?
Does the probe plug into a wire harness on this model or directly into the oven control?
Plugs into a wire harness.
I have run into problem once in awhile with the probe making a bad connection were it plugs into the wire harness. Many of the replacement probes even come with ceramic wire nuts so you can remove the plug and wire nut the new probe in, just been my experience with them.
I can check the connection again. Do you need ceramic wire nuts or can you use a standard electrical wire nut?
Is there anything other than the probe that codes F1 and F3 I should be looking at?
I would stick with ceramic wire nuts because of the heat from the oven. It's possible it could be a problem with the oven control.
