Dryer will not start even after replacing the timer controller.Has power to plug and controller.What else
Most likely the problem is a blown thermal fuse located on the heater housing. The thermal fuse comes as a part of the kit which includes the high limit thermostat and the installation instructions. - The part number for the kit is AP4242472Gene.
