Can anyone tell me how to remove the front stainless steel trim panel on a Thermador GPS366S? This is the piece behind the knobs and chrome bezels that must be removed to service the control potentiometers.
It appears to be glued to the edges of the front bullnose piece. Before I pry too much I would like to make sure that is how it is really attached.
thanks Dave Christensen
I know this is late, but for all of you DIY folks... Remove the two bottom screws then pull slightly on each side, while cutting the double-sided tape holding the front panel on. Once the tape is cut, the panel will release. The panel is released from the top clip when you pull the bottom toward you.
