Unit is a side x side. Items in the top of freezor side are thawing and items in bottom of fridge side are freezing. What could it be?
You have been a member since:: 2/29/2008(UTC) Views messages in topic : 19,638
Here are your parts Model TFX20JRBEWWCould be the evaporator fan in the freezer is not working. Air must circulate for even temperatures in both compartments. Could also be a defrost problem. Remove the cover and check the evaporator coils in the freezer to see if they are heavily iced over |
THIS FORUM IS DEAD!!!!!!! |
