jeremy69
#1 Posted : Friday, February 6, 2009 1:52:40 AM(UTC)
jeremy69
I have a kenmore furnace made by sears. I'm have pilet lighting issue not sparking when i turn on the furnace and it's blowing out cold air... what should I do, on this matter? I think my blower unit went out last night too it's making a funny noise and it's really loud to would that cause this problem?? if so, how hard will it to be replace it?
ernesto1959
#2 Posted : Friday, February 6, 2009 10:40:26 AM(UTC)
ernesto1959
be sure the fan wheel is secured to the motor , motor turns freely. If you find a problem with it . like blower wheel damaged or stuck in housing , most likely u will have to replace : fan wheel , blower motor and capacitor in case it have it. power must be off all the time , check it out what is the noise so you can move to the next step , but first let us see that noise problem.
icehouse
#3 Posted : Saturday, February 7, 2009 3:07:50 PM(UTC)
icehouse
[FONT=&quot]Problem[/FONT][FONT=&quot]: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation: [/FONT]
[FONT=&quot] [/FONT]
[FONT=&quot]1. Thermostat calls for heat.[/FONT]
[FONT=&quot]2. Draft inducer motor starts.[/FONT]
[FONT=&quot]3. Pressure switch attached by a small plastic or rubber tube senses the[/FONT][FONT=&quot] negative pressure produced by the draft inducer and closes.[/FONT]
[FONT=&quot]4. Draft inducer runs for 30 seconds to a minute before you hear a gas[/FONT][FONT=&quot] hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas.[/FONT]
[FONT=&quot]Solution[/FONT][FONT=&quot]:[/FONT][FONT=&quot] You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. [/FONT][FONT=&quot]Make sure you do not touch the ignitor with your bare hands[/FONT][FONT=&quot]. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. [/FONT][FONT=&quot][/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]
[/FONT]
