ibrahimdd
#1 Posted : Tuesday, November 13, 2007 8:46:26 PM(UTC)
ibrahimdd
I suspect lose connection in the power baord. the power board, looks like, it suppose to slide upward, but it won't, even though I use extreem force, like big hammer.
Abe
#2 Posted : Wednesday, November 14, 2007 6:36:25 PM(UTC)
In order to remove the control panel you have to remove the top grill first and then remove the screw, holding the control panel.
What exactly is wrong with your microwave? Does it exist after a big hammer used?
- Here are the break down diagrams for the GE microwave Model JVM1861SD002
ibrahimdd
#3 Posted : Thursday, November 15, 2007 7:09:03 AM(UTC)
ibrahimdd
Gene...I am 70, I start at 20, There are no scews, Panel suppose to slide upward, Has 6 fingers sticking thrue the frame" ---1" in this shape, saw hundreds but not this type.
All have screws top and bottom, this has no screws. could not push it up, so with a piece of wood and a hammer, I tried to push up in case it is stuck, no move...
Thank you for your help, try again
This micro. has no print inside as normal. Does GE has techn. support.
Abe.... tel.&fax 707 586 0543
