Bella James
#1 Posted : Friday, December 2, 2011 10:19:33 AM(UTC)
Bella James
I have a frigidaire side by side refrigerator/freezer. When I dispence water from the fresh water, the dispensor continues to drip. Also the icemaker freezes at the water intake to the icemaker. My question is : Do I have 2 seperate issues with the water not shutting itself off completely, or is there a common part that will prevent these problems. Either way - What are the parts and part #'s
ApplianceJunk
#2 Posted : Friday, December 2, 2011 4:26:04 PM(UTC)
ApplianceJunk
Could be the water inlet valve on the back of your refrigerator is faulty and needs to be replaced.
I have also seen problems like this created from low water pressure to the refrigerator. If you are sure the water pressure to the refrigerator is fine I would consider replacing the water inlet valve.
Guest (4)
