gdog997
#1 Posted : Friday, December 2, 2011 8:52:20 AM(UTC)
gdog997
whirlpool ed22tqxgn00 does not dispense water. Ice maker makes ice and dispenses. Removed front cover and checked micro switch form continuity, checked actuator arms for damage. Finally I order new two way water valve and installed but have same problem. When water switch is pushed you can hear the valve hum. Any additional ideas ?
ApplianceJunk
#2 Posted : Friday, December 2, 2011 4:29:21 PM(UTC)
ApplianceJunk
The water line that runs between the water inlet valve and ice maker is most likely frozen shut and will need to be defrosted.
no water dispensed (Refrigerator & Freezer Repair)
by morzil 4/23/2009 8:31:10 PM(UTC)
