2 Pages12>
Blue38
#1 Posted : Tuesday, November 29, 2011 10:21:44 AM(UTC)
Blue38
Weeeyup-weeeeyup type wind up noise from top of unit. Can not detect the source. New Evap fan & bushings installed. Any Assistance????
#2 Posted : Wednesday, November 30, 2011 3:12:28 AM(UTC)
Your freezer motor is probably too loose, add some rubber gromets to the end bells to stiffen them up.
Blue38
#3 Posted : Wednesday, November 30, 2011 8:58:58 AM(UTC)
Blue38
I have replaced the evap motor & bushings.
Blue38
#4 Posted : Wednesday, November 30, 2011 9:00:34 AM(UTC)
Blue38
Blue38
#5 Posted : Thursday, December 1, 2011 7:24:23 AM(UTC)
Blue38
This is not constant noise, like a fan running. When the unit is running the sound is coming from the middle upper right on the back/while facing the back. The sound is more pronounced from the outside with little noise from the inside. Icemaker works-no frost build up inside-all compartments cooling-solenoid type wind up noise-like something to engage. Thanks
#6 Posted : Thursday, December 1, 2011 8:42:08 AM(UTC)
The noise may be coming from the evaporator capillary line. You might have refrigerant contamination, measure the freezer temperature and post.
Blue38
#7 Posted : Friday, December 2, 2011 10:27:42 AM(UTC)
Blue38
Freezer temp 8 degrees, control setting #3. I removed the inner freezer panels, the evaporator was frosted /not frozen over. Using my pinpoint stethoscope, the noise was coming from the top of evaporator by the insulated bulb & capillary line. I defrosted the evap with a hair dryer-less noise now. Possible defrost timer and or heating element???? What is your opinion?? Should the evaporator coils be free of frost completely when checking out this issue??? Thanks
#8 Posted : Friday, December 2, 2011 11:09:46 AM(UTC)
You may have had only a partial defrost, most likely a defrost thermostat going bad, I would probably replace it.
Your freezer temperature must be lower now, just check and post.
Blue38
#9 Posted : Sunday, December 4, 2011 8:29:56 AM(UTC)
Blue38
Freezer at 0 degrees-very noisy last night again. I will pull the panels again and defrost with hairdryer if needed. Should I purchase the heating element/thermostat assy and a defrost timer?? OR which unit should I purchase and replace first to solve this issue? Thanks
#10 Posted : Sunday, December 4, 2011 9:47:05 AM(UTC)
Your problem is not a defrost problem. If the lowest temerature the freezer will go down to is zero, you might have a partial restriction in the capillary line.
2 Pages12>
