tgrenchik
#1 Posted : Sunday, November 27, 2011 5:43:36 PM(UTC)
tgrenchik
I have a Bosch SHU3305 (FD 8207) DW that will run forever without delivering water. I cleaned the screens and removed the cover on the prop and cleaned the backfill valve. There is a very slow drip underneath the unit (about center-left). Any idea what might need replacing?
Thanks!
TG
TommyH
#2 Posted : Sunday, November 27, 2011 6:17:19 PM(UTC)
TommyH
Is it the drain pump that is running?
tgrenchik
#3 Posted : Monday, November 28, 2011 1:30:39 PM(UTC)
tgrenchik
Thanks TommyH.
Problem started with extra water in bottom of tub.
So I did the cleaning.
Then I poured a gallon of water in the tub to "prime it" and when the DW first starts up it drains that water out... so I'm guessing the pump is working and the drain line is clear.
But I don't hear any audible changes, so yes, maybe its the pump not shutting off.
When left on for a while,the DW will shut off and start up again.
When I ran the "test" it registered "Regular Wash = water filling fault (over or under filling)".
Any ideas?
Thanks so much!
T Grenchik
EmilyWatson
#4 Posted : Wednesday, November 30, 2011 10:07:05 PM(UTC)
EmilyWatson
HI TOMMY .I bought Bosch product and i had some problems as well.You can get all the help required for fixing or reparing these products from fixya.com.Hope you might get solution.
____________________________
Power Supplies
