mikeg1303
#1 Posted : Wednesday, February 4, 2009 6:58:55 PM(UTC)
mikeg1303
My Maytag dryer is banging against the left side of the housing. It seems to be hitting from the same spot on the drum and making a loud noise. Any suggestions and appropriate diagrams would be greatly appreciated.
kayakcrzy
#2 Posted : Thursday, February 5, 2009 1:32:15 AM(UTC)
kayakcrzy
it is most likely the drum rollers. it would be best to replace the 2 drum rollers, and the idler pully, and the belt. do it all at one time. if you are looking for a service manual, go to the "maytag service library", and click on literature by model #, and put in your model. tom [url=]applianceeducator.com - parts[/url]
magician59
#3 Posted : Thursday, February 5, 2009 8:40:42 AM(UTC)
magician59
Also, look for loose baffle screws. Tighten them.
mikeg1303
#4 Posted : Saturday, February 7, 2009 9:19:30 AM(UTC)
mikeg1303
Thanks for the advice. I opened up the front panel by removing 4 screws and discovered a loose baffle screw. I tightened it up, re-assembled the front panel and I am back in business. E-Z fix, and I saved a lot of money!
