Here are your parts.
Replacement parts for WHIRLPOOL TEDX640JQ1 DRYER | AppliancePartsPros.com[COLOR="DarkRed"]
Would the identified part(s) account for no heat in the dryer, or am I missing something?[/COLOR]
You are correct that a blown (open) thermal cut-off will kill power to the heating element but there are other things that should be checked before replacing it.
See the attachment for your wiring diagram.
The cycling thermostat may be OK but I cannot be 100% sure, see
Blown Thermal Cut-off below.
One set of connectors are the contacts. The other set is an internal heater. It is turned on during low heat cycles. It adds heat to the thermostat so it cycles more often and results in lower heating element output. It should measure between 5600 and 8400 ohms.
If you are using too low of a meter scale it could look like an open when in fact it is OK.
Blown Thermal Cut-offCheck the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
