Found that it has a broken shock absorber. Would this cause it to be out of balance and not run? Sometimes it will hum for about 3 seconds and then just stop. Other time the door will just lock and it won't do anything. Error code is E59. Wonder if it could be the control board also... Any help is appreciated.
Motor checks out good in test 12 of the tech manual
