The washer works great but the dryer drum is not spinning correctly. It is as if the drum is supposed to be supported in the back by a post or something but there are no broken pieces inside and no place for a post to connect. The belt is not broken and spins the drum but the drum is fall back and does not stay horizontal. Before it started falling back it was sqeaking. Could belt be stretched and it was sqeaking then finally allowed the drum to fall back. Does the belt even support the drum at all.
There is a bearing in the back of the dryer. Here's a parts breakdown of one very similar to yours. It uses the same bearing and glides as yours. Model FLEB8200FS0 on page 7, parts locations 12 & 13 and parts 23 & 24 are probably they parts you need to look at. Nat
Thank you I will check that out and let you know how it did.
