Keetoe
#1 Posted : Sunday, February 1, 2009 9:31:20 AM(UTC)
Keetoe
The right side temperature display (LCD?) has lost illumination. Do I have to replace the Control Module (Part: AP4090010 made by WHIRLPOOL)? Or is there a bulb someplace? Or some problem elsewhere? Thanks, Keith
ApplianceJunk
#2 Posted : Sunday, February 1, 2009 11:26:51 AM(UTC)
ApplianceJunk
I believe so.
Keetoe
#3 Posted : Monday, February 2, 2009 5:12:04 PM(UTC)
Keetoe
Originally Posted by: ApplianceJunk Go to Quoted Post
I believe so.
Thanks. If that doesn't do it, I'll get back.
Keetoe
#4 Posted : Tuesday, February 3, 2009 6:29:30 AM(UTC)
Keetoe
Hi William. The make/model is at the top of the original post: Amana ACB6260AB . The control is made by Whirlpool. Note: This is a conventional in-wall double oven. It appears that if the problem is inside the module, it probably has to be replaced (highly integrated PC board with LCD bonded to it). However, if it is external, like a temperature sensor, a new module won't be the cure. Thanks, Keith
Guest (4)
