Kaye
#1 Posted : Monday, February 2, 2009 2:04:24 PM(UTC)
Kaye
GE monogram dishwasher. Some options on touchpad control panel work (pots & pans , rinse & hold, lock, delay start) other touchpad control panel options do not respond (normal, heated dry, reset). Any thoughts, other than junk the GE? Thank-you.
#2 Posted : Tuesday, February 3, 2009 4:40:43 AM(UTC)
Model ZBD3500X66WW
Probable cause is switch membrane Item 957 in Section 3
Looks fairly simple, should be able to check the switches with a meter.
Usually a number of switches use a common track in the ribbon cable.
Looks like finding a replacement could be a hassle.
May want to try the below
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
I am off to the lake for a week but there are many on this forum who will help you if you get stuck.
