i was testing the rectifier wrong - i replaced the mangetron with the new one again this time with the new rectifier and it is working :) :) :) :)
thanks
If you did put back the old magnetron then it's possible that the bad magnetron damaged the new diode.
my frigidaire is doing the exact same thing no noise everything works but does not heat what can it be
What is the complete model number of the microwave?
Did you do any tests so far?
