My Frigidaire microwave will not heat. All other functions are ok lights, timer, turn table etc. is there a internal fuse i can replace or is it just the magnetron?
FRIGIDAIRE Frigidaire/microwave PLMVZ169GCA
No it sounds normal, internal fan runs, light is on, table turns
Sounds like the magnetron is the culprit.
That works for me, the wiring diagram was hard to read I wanted to be sure there was not a fuse that was cheaper.
Anyone aware of a warranty for the magnetron? I hear that some extend beyond one year?
Replaced the magnetron, still won't heat and now there is a louder noise when the unit is running
ok - i replaced the rectifier it tested bad and the new one tests ok - still no heating - making a low toned buzz - different from before? i went back to the old magnetron based on the rectifier being bad - should i put in the new magnetron or is there another piece to the puzzle??
i decided to test the diode again and it is showing no continuity from either direction - my guess is something fried the new one? what else can i replace or test?
