You have been a member since:: 11/25/2011(UTC) Posts: 2
My dishwasher has no lights on the control board when the doors closed, I checked the power coming in and have 120vs, not sure how to proceed. One thing I'll say is the latch is broken, but has been for a long time.
Help?
A model number may help others help you. Model Number LocatorIt could be that the door latch has finally broken to the point where it is not closing one of the door interlock switches. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  A model number may help others help you. Model Number LocatorIt could be that the door latch has finally broken to the point where it is not closing one of the door interlock switches. Its a quiet series 100 maytag, as far as the door latch being broken and not making proper contact, how do i go about checking it? I was thinking it maybe the control board.
Series 100 is the model not the model number.
They may make half a dozen different models using this model name. So to find a wiring diagram I need the model number. Even then I may not be able to find one. |
