henrylockett
#1 Posted : Monday, February 2, 2009 9:52:56 AM(UTC)
henrylockett
Water has began to appear in bottom of refridgerator under the crisper drawers
#2 Posted : Monday, February 2, 2009 6:00:05 PM(UTC)
Most likely the problem is a frozen drain. Remove the rear panel in the freezer and locate the drain hole under the evaporator. You can defrost it using a hair dryer and/or a turkey baster with hot water. Also remove the cover on the back of the refrigerator and check the other end of the drain tube for a clog.
