Dishwasher monitor stuck on clean therefore, It wont start a new cycle. Dishwasher will work if rinse cycle is selected but it only rinses. It is a KitchenAid Whisper Quiet
Your model # won't work. But it sounds like a stuck keypad.
Originally Posted by: LATONYA007  Dishwasher monitor stuck on clean therefore, It wont start a new cycle. Dishwasher will work if rinse cycle is selected but it only rinses. It is a KitchenAid Whisper Quiet This problem just started with my dishwasher which is also a KitchenAid Whisper Quiet, model # KUDS24SEBS4. How can I fix the keypad, if it's stuck? What else could be the problem? Thanks!
Same problem you guys have, anyone find a solution???
No repair possable for a stuck keypad, must replace it.
Originally Posted by: richappy  No repair possable for a stuck keypad, must replace it. I don't know what the hell that last post was??? Anywho thanks for responding to my post and to just be clear, does that mean I can replace the keypad or do I need to replace the dishwasher itself?
Look up the part on this parts site above, you will need your model#
