gvalen
#1 Posted : Tuesday, November 13, 2007 9:37:21 PM(UTC)
gvalen
:confused: Hoping someone can help. My electric dryer recently stopped drying, it runs but doesn't heat. I just changed the heating element, thermostat and cut off fuse at the same time and heating element came on. I thought it was fixed but stopped heating within 30 minutes?? Any idea on what else it could be, wiring seems in tact. Could it be the dryer thermostat??
model# 110.86873800 -kenmore electric dryer
Thanks.
#2 Posted : Wednesday, November 14, 2007 6:44:42 PM(UTC)
The first thing I would check is the thermal fuse.
Check the thermal fuse for continuity and replace if it's open.
The thermal fuse
UserPostedImage
- The part number for the thermal fuse AP3132867
Also check the vent, the air ducts inside the dryer and the blower. Looks like the dryer was overheated.
abbie
#3 Posted : Thursday, November 15, 2007 4:58:37 PM(UTC)
abbie
First Make Sure There Is 240 Volts Going To Dryer.
Guest (5)
