usermcloed
#1 Posted : Wednesday, January 28, 2009 4:43:23 PM(UTC)
usermcloed
Refrigerator is 2 yrs old. Water stopped dispensing. I changed water filter and reset it. Now very little water is dispensed and sometimes it stops working. Icemaker not working. Icemaker is turned on and freezer temp is at -1. Freezer is working properly. I checked waterline valve and it is turned on. I noticed that I haven't heard it making the usual sounds as before. What else should I check for. Thanks.
#2 Posted : Thursday, January 29, 2009 8:27:32 PM(UTC)
What kind and part number of the water filter did you use?
Double check the filter installation.
Turn off the water shut off valve, disconnect the water line from the refrigerator and check the water pressure in the line.
jrogers
#3 Posted : Friday, January 30, 2009 3:06:51 AM(UTC)
jrogers
Gene,
I have small kink in my copper line feeding my ice maker. The kink decreases the diameter of copper tubing by an estimated 1/2 diameter. Should I replace the entire length of copper tubing, replace the length that has the kink, or nothing at all?
#4 Posted : Monday, February 2, 2009 11:42:04 AM(UTC)
I would recommend to replace the whole copper tube and use the stainless steel braided water line connector instead of copper tube.
- The part number for the 60" line is AP3515761
