kdfischer
#1 Posted : 16 years ago
kdfischer
The refrigerator is a GE TFX25JRBA WW side-by-side. Just hooked up water line to unit. The water and ice just plain old taste bad. It can't be the water from the home because I just moved and the water was bad at the other place too. It tastes the same here as it did there.
I've looked and can't find a filter anywhere that needs to be replaced. Am I blind or stupid?
Any suggestions?
Kevin
#2 Posted : 16 years ago
Hi Kevin,
There is no built-in water filter in this model, so do not blame yourself. You definitely have to install an in-line water filter to improve the water taste.
- The part number for the GE in-line water filter is AP2615841
