tmcoleman
#1 Posted : Thursday, January 29, 2009 1:20:36 PM(UTC)
tmcoleman
I need help installing a new check valve. Is there a trick that may simplify getting it in place?
Thanks,
tmcoleman
tmcoleman
#2 Posted : Thursday, January 29, 2009 5:47:10 PM(UTC)
tmcoleman
Perhaps I haven't recieved any input because I didn't explain my dilemma clearly enough? There is nothing to unscrew to access where the check valve sits, or if there is I haven't found it! The only way I can see to insert it is a VERY small space thru a small hole. Is there a special tool required on this model? :confused: The DW is 6 years old.
Guest (4)
Check valve replacement (Dishwasher Repair)
by marc74 11/18/2009 11:45:24 AM(UTC)
