2 Pages<12
thenextone
#11 Posted : Thursday, January 29, 2009 11:10:55 AM(UTC)
thenextone
now when i did this i disconected the two prongs red and red and white and put a wire into each end. is that the correct way?
#12 Posted : Thursday, January 29, 2009 1:57:28 PM(UTC)
Yes as long as the wire you used made good connection to both plugs.
Or if the receptacles ion the ends of the wire are bare metal just tape them together.
Also double check that it was the thermal fuse you shorted and not the operating thermostat which has the same color wires going to it. The thermal fuse should be marked 309 or 325 degrees or something like that.
thenextone
#13 Posted : Thursday, January 29, 2009 2:00:14 PM(UTC)
thenextone
theyve got plastic covering them. but the wire should have made good connection. this was number six the one on top. should i try it with the one on the bottom
2 Pages<12
