Rank:: Member
the refridgerator is not working but the freezer side is, i have vaccumed out from underneath it but it did not help anyone out there with any ideas?
It's possible the evaporator coil is iced up not allowing proper air flow to the fridge; defrost problem, inspect the rear inside wall of the freezer for a frost buildup, post back on your results... cheers, kooler
