I have had repair services out numerous times to correct the temperature swings in this oven. We replaced an 25 year old Thermador wall oven with a new Frigidaire model GLEB30S8CQ. This oven cannot maintain a constant baking temperature. Cakes my wife has baked for over 40 years all fall with this oven.
For example, pre-heat the oven to 350 degrees and the temperature rose to +/- 410 degrees. the interior temperature then dropped to 330 degrees before the heating element came on again.
The oven then went from 330 degrees to 390 degrees and then dropped to 331 degrees.
This cycle never varies more than a couple of degrees.
Help please,
PCD
Hi pcdondero
What exactly was done by the repair services and when?
Please, post the reply as a new thread.
