2 Pages12>
thenextone
#1 Posted : Monday, January 26, 2009 2:14:34 PM(UTC)
thenextone
hello i have the roper by whirlpool. the dryer will turn and blow air but its cold air. the timer dile will not count down either. i took off the heating element and its intact. do you think its the thermostat element?
thenextone
#2 Posted : Monday, January 26, 2009 6:09:33 PM(UTC)
thenextone
does the element come with the thermostat in it?
thenextone
#3 Posted : Monday, January 26, 2009 6:46:41 PM(UTC)
thenextone
do you think the heating element would fix the problem?
#4 Posted : Tuesday, January 27, 2009 4:15:55 AM(UTC)
Model REX6634PQ0
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208528187.pdf
First I would check the breaker/fuses. Turn the breaker off/on slowly a couple times. Often you can loose half the line voltage without actually tripping the breaker. Depending which side drops out the units motor will run but you get no heat or timer advance in either timed or auto modes. Both the heater and the timer require 240 volts. If the timer advances on timed dry then your 240 is probably OK and the heater is probably open.
On Auto modes the timer gets power through the heater coil when it is turned Off by the thermostat.
thenextone
#5 Posted : Tuesday, January 27, 2009 8:56:13 AM(UTC)
thenextone
so what do you guys recomend? old lady nagging me to get it fixed.
#6 Posted : Tuesday, January 27, 2009 1:31:05 PM(UTC)
Thought I had given you a recommendation.
So here is another one
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
Use the meter to check that you have 240 volts.
If you have the 240 then use the meter to check the heating components.
Unplug the unit.
thenextone
#7 Posted : Thursday, January 29, 2009 7:38:40 AM(UTC)
thenextone
ok i tried the breaker on off a few times no luck dont know how to use a meter tester thing. should i just buy a new dryer? what would you guys suggest the most common things to go out on these? with what ive described? thanks rex
#8 Posted : Thursday, January 29, 2009 8:22:07 AM(UTC)
Cannot answer this, it is up to you. The dryer is relatively new, if you feel uncomfortable messing with it, you may want to place a service call but it should not be a difficult fix and you will save yourself at least $50.00 to $100.00.
Most common would be the thermal fuse in the heater circuit (look at the wiring diagram)
Here again is the link to your parts, just so it is handy.
Model REX6634PQ0
Take a look at in the "Bulkhead Parts" section Item 6. You will see that it is a fuse and a high temp thermostat. They come as a set. The fuse can be checked without a meter.
Unplug the machine
Remove the two wires from the thermal fuse and short them together
Tape them up so they cannot short to anything.
Plug the unit back in and give it a try.
If it now runs order the parts.
Replace the fuse and high limit thermostat ASAP as they are safety devices.
Make sure you have the unit unplugged when working on it. It is 240 volts which is very dangerous.
If it is the fuse that is blown, clean and check your vent system. A dirty/clogged vent or vent louvers which do not open properly are a common cause of this fuse blowing. Also make sure your lint filter is clean.
If you use liquid fabric softener it can coat the screen drastically reducing air flow. If this is the case clean it with soap and water. Let it dry good before reinstalling.
thenextone
#9 Posted : Thursday, January 29, 2009 8:23:59 AM(UTC)
thenextone
thank you sir ill try this
thenextone
#10 Posted : Thursday, January 29, 2009 11:08:00 AM(UTC)
thenextone
tried that and that did not work any other suggestions?
Guest (4)
2 Pages12>
