bryker28
#1 Posted : Tuesday, November 15, 2011 3:42:50 PM(UTC)
bryker28
I have a Roper by Whirlpool Dryer with Mod number RED4440VQ1 on inside of door . The dryer is running and it is also heating but it takes 3 or 4 cycles for a normal load to dry completely. I have no background in this area so a detailed description of what to do would be helpful. Thanks!
#2 Posted : Wednesday, November 16, 2011 7:26:58 AM(UTC)
Could be a vent problem
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
SublimeMasterJW
#3 Posted : Wednesday, November 16, 2011 8:04:27 AM(UTC)
SublimeMasterJW
Took some photos for all yall DIY folk:
ApplianceJunk.com Blogspot: Roper Dryer Tune-up
