cant buy tub. any ideas on repair or patch? other models have been recalled but not mine.
I cannot find any info on the given model number, please check it.
Also if you have the operators manual check the warranty often the tub has an extended warranty.
As far as repair it depends where the crack is and how bad it is. Very difficult to fix if on or near a bend. |
THIS FORUM IS DEAD!!!!!!! |
Model MDB5600awb not 6500
Go to the Maytag website and under "OWNERS CENTER" / " Manuals and Literature" Download the warranty sheet for your unit, it says the tub has a twenty year warranty. |
