I replaced the drum belt, but when I pulled the front panel off the clips flew on the floor. Now I can't figure out how to get the front panel back on.
I know, dumb question.
The clips mount on the top of the front panel. Put them both in the same way. You can put them in backwards. But if you put them both in the same way, and then push the top part of the front in, at a 45 defree angle, and then push the bottom of the front toward the washer. It should fit perfect. If not, reverse the clips. Tom ApplianceEducator.com
