I have check the drain filter and it is clean, when the machine goes to the rinse cycle it will not rinse/spin or drain, the machine is running but not doing anything.
Originally Posted by: rangers02  I have check the drain filter and it is clean, when the machine goes to the rinse cycle it will not rinse/spin or drain, the machine is running but not doing anything. Did you get a fix? We're debating on getting it fixed or replacing it because of the minimum $100 evalution visiti.
