dianeb
#1 Posted : Thursday, January 22, 2009 9:08:00 AM(UTC)
dianeb
I have a Dacor double oven cps227 with inside cracked glass.
I can pick up part#12470 which is a window pack.
How do I take off old part and how do I install new part? Directions or advise. Will I need anything else, (new gasket)
Thanks,
Diane
#2 Posted : Saturday, January 24, 2009 3:26:17 PM(UTC)
Hi Diane,
You have to remove the door from the oven first. I believe you can find the instructions on how to do it in the Owners manual.
Place the door on a flat surface with the door handle facing down, remove the screws holding the inner liner and remove the liner. Follow the break down diagram for the further disassembly.
- The part number for the window pack is AP3395046
