dppham
#1 Posted : Friday, January 23, 2009 7:20:21 AM(UTC)
dppham
Im helping a friend fix their refrig. the freezer is not cold. i can hear the fan running. ice maker not worker either... but the motor works..
i already cleand the condenser. and then freezer seemed to be working but then it died again later that night.
later tonight im coming back over to test the tememper control switch then the defrost timer.
i fixed a whirlpool refrig with the same problem and it ended up being a fuse inside the freezer. its about a 3 or 4 inch long fuse. but i cant find any fuses on the amana.
anyone with advice?
